Is there a tip for filling a large number of input/output data in a lookup graph? In my case, a goal is to specify hundreds of data points (kept in Excel) to make a lookup graph. This, if done manually, is time-consuming and vulnerable to mis-specification.
Hope you can help.
Monte
Making Lookup Graph
In addition to the get_xls_lookup function already mentioned, if you arrange the data pairs in Excel and copy them to the clipboard, you can "import" from the clipboard using the "import vals" button in the bottom-left of the equation editor (when looking at a lookup table equation in "as graph" mode).
