Was trying to model Jay Forrester's market growth model and ran into a simultaneous equations error.
Essentially - this was on 'desired capacity'. If desired capacity is a floating goal vis-a-vis actual capacity, then I was not able to initialize desired capacity.
Vensim gave me a simultaneous equations error. Looking up at the manual, I reformulated the equation for desired capacity and it worked ok.
But, is there a way to solve this problem without using the 'SIMULTANEOUS' function?
Model is attached - Its not complete, and only two of the sectors have been done in it so far.
Malli
Simulataneous Equations Error
- JWF_Model.mdl
- (6.02 KiB) Downloaded 466 times
You need to see how this was originally formulated. It is possible Jay simply used a number as you have. In general for formulating initial condition it is good to try to put things into some sort of equilibrium or steady state - though for this model that does not really make sense. My recommendation if you do not want to follow Jay directly would be to put in the constant initial capacity.
