I have a model using Time,TIME STEP, FINAL Time. But i really dont know what are those for and how to use them. are they the default parameters in vensim? If i wanna convert them in STELLA, how should i do? the example model using those variables is in the attachment. Can anyone explain this model for me, especially the usage of Time, TIME STEP, FINAL Time in the model? also, how to use them in STELLA? Thank you very much again!
Vensimer
About Time,TIME STEP,FINAL TIME?
- CHANGE.MDL
- (13.21 KiB) Downloaded 98 times
They are parameters required in every continuous time based simulation.
A good description is here
http://www.vensim.com/documentation/html/22165.htm
Unless there are any active Stella users on this forum, there is little chance of you getting help on how to implement these.
All the best,
All the best,
