What I want to do is create a program in c# that uses vensim DLL to load a model and run.
The problem is I cant figure out how to tell the dll how long to run the simulation for. It only runs the time hard coded into the model.
As a seperate question, is it possible to query the DLL to retrieve the name of the input file (in this case an xls file).
How to set the Final Time through the DLL
