problems with the button
Moderator: Administrator
I have a problem with the button, when I enter its properties the option button I put simulation and in commands I put continues game soon I press ok does not respond ok follows in the same option somebody can help me
I just downloaded SABLE Lite, and tried to test the button's performances. Under "Button" Tab, as I set "Simulation" a radio-button window appears (Silmulation Command) displaying all possible options; if I select any of the possible choiches, the "OK" button doesn't work, so it is not possible to associate the proper comand to the button.
Is there any "trick"?
[the model is a simple flow/level, just to test the Sable ...]
thanks Paolo
[Edited on 5-3-2007 by pz]
thanks Paolo
