Transform annual data into monthly cumulative data
Re: Transform annual data into monthly cumulative data
Yes, but from this variable I need to find the maximum value that another variable reaches during the month. This new variable must compare the value at time = 1 with the value at time = 0 and so on, always providing the maximum value.
You already have all you need.
maximum value in month = SAMPLE IF TRUE ( new month trigger = 1 :OR: maximum value in month < YOUR LEVEL , YOUR LEVEL , YOUR LEVEL )
Problem solved.
Thank you.
Thank you.
Sorry for the nuisance again, but there is some function that takes values over time for a given variable and provides the mean, for example:
variable X = 2,4,3,5,2,2
desired variable = 0,3,0,4,0,2
In this case the average of the variable X is calculated every two time intervals and presented.
Thank you once again.
