(Excel and Vensim)link
Re: (Excel and Vensim)link
Install the Vensim Model Reader (not PLE).
You are right. I selected the wrong option.
I try to install it but:
- pic.jpg (27.99 KiB) Viewed 23523 times
Can you try downloading again? It may be that the download was corrupted.
I could try to downloading it again. I could install it.
But :
But :
- Pic2.jpg (95.69 KiB) Viewed 23521 times
Open Excel, you do not need the model reader or Vensim DSS open.
Now run the "RunModelMultipleTimes" macro.
Thank you Tony .
I'm Sorry to bother you.
I do as you said. It gives the same error. always, I have to open the Vensim program at first. if I don't open it ,I can't run any macro.
I'm not hoping that my DLL works. I think I have to find a way to change the model that Tom edited for me. I can work with DDE problem easily.
You do not need the model open in Vensim for it to work.
What happens when you run the macro?
In my models (not Book2), I have to run these macros and Vensim should be open:
And then I can run other macros.
In Book2(the model that you edited for me) ,with or without opening vensim the error is:
Sub StartupDDE()
DDE_channel = Application.DDEInitiate("VENSIM", "System")
End Sub
Sub LoadVensimModel()
varstr$ = "[SPECIAL>LOADMODEL|" + Cells(2, 7).Value + "]"
Application.DDEExecute DDE_channel, varstr$
End Sub
- pic.jpg (19.58 KiB) Viewed 23513 times
ok. Try publishing the model again, select package type "Other (using Vensim DLL)" and selecting the "caller" as Excel. You will need to look into the help system to do this properly.
If you can reinstall Vensim DSS ensuring that vendll32.dll is installed, it will all work ok for you. You mentioned in a previous post that you installed lots of times, but then said someone installed Vensim for you. If someone installed it for you, get them to install again and make sure the DLL is installed correctly.
Thank you Tony for your help.
Yes, someone installed it for me for 5 times at a day, But vendll32.dll automatically saved at "C:\Windows\System32". They selected the DLL option at each time. and don't give me this software.
Your forum is the best forum that I've ever seen. I'm really grateful to you .
You help me so much, but finally because of software problem I can't get result.
In the last example I sent, I modified the code to load vendll32.dll from c:\windows\system32.
In the VBA file, at the top it should look like this (I changed "vendll32.dll" to "C:\Windows\System32\vendll32.dll", so it should work on your computer).
Is this the code you are using?
Private Declare Function vensim_be_quiet Lib "C:\Windows\System32\vendll32.dll" (ByVal quietflag As Long) As Long
Private Declare Function vensim_check_status Lib "C:\Windows\System32\vendll32.dll" () As Long
Private Declare Function vensim_command Lib "C:\Windows\System32\vendll32.dll" (ByVal Vcommand$) As Long
Private Declare Function vensim_continue_simulation Lib "C:\Windows\System32\vendll32.dll" (ByVal number_time_step As Long) As Long
Private Declare Function vensim_finish_simulation Lib "C:\Windows\System32\vendll32.dll" () As Long
Private Declare Function vensim_get_data Lib "C:\Windows\System32\vendll32.dll" (ByVal filename$, ByVal varname$, ByVal timename$, varvals As Single, timevals As Single, ByVal maxpoints As Integer) As Long
Private Declare Function vensim_get_dpval Lib "C:\Windows\System32\vendll32.dll" (ByVal varname$, varval As Double) As Long
Private Declare Function vensim_get_dpvecvals Lib "C:\Windows\System32\vendll32.dll" (vecoff As Long, varvals As Double, ByVal veclen As Long) As Long
Private Declare Function vensim_get_info Lib "C:\Windows\System32\vendll32.dll" (ByVal infowanted As Long, ByVal buf$, ByVal maxbuflen As Long) As Long
Private Declare Function vensim_get_sens_at_time Lib "C:\Windows\System32\vendll32.dll" (ByVal filename$, ByVal varname$, ByVal timename$, attime As Single, vals As Single, ByVal maxpoint As Long) As Long
Private Declare Function vensim_get_substring Lib "C:\Windows\System32\vendll32.dll" (ByVal fullstring$, ByVal frompos As Long, ByVal buf$, ByVal maxbuflen As Long) As Long
Private Declare Function vensim_get_val Lib "C:\Windows\System32\vendll32.dll" (ByVal varname$, varval As Single) As Integer
Private Declare Function vensim_get_varattrib Lib "C:\Windows\System32\vendll32.dll" (ByVal varname$, ByVal attrib As Long, ByVal buf$, ByVal maxbuflen As Long) As Long
Private Declare Function vensim_get_varnames Lib "C:\Windows\System32\vendll32.dll" (ByVal filter$, ByVal vartype As Long, ByVal buf$, ByVal maxbuflen As Long) As Long
Private Declare Function vensim_get_varoff Lib "C:\Windows\System32\vendll32.dll" (ByVal varname$) As Long
Private Declare Function vensim_get_vecvals Lib "C:\Windows\System32\vendll32.dll" (vecoff As Long, varvals As Single, ByVal nelm As Long) As Long
Private Declare Function vensim_set_parent_window Lib "C:\Windows\System32\vendll32.dll" (ByVal vwidnow As Long, ByVal r1 As Long, ByVal r2 As Long) As Long
Private Declare Function vensim_show_sketch Lib "C:\Windows\System32\vendll32.dll" (ByVal viewnum As Long, ByVal wantscroll As Long, ByVal zoompercent As Long, ByVal Vwindow As Long) As Long
Private Declare Function vensim_start_simulation Lib "C:\Windows\System32\vendll32.dll" (ByVal loadfirst As Integer, ByVal game As Long, ByVal overwrite As Long) As Long
Private Declare Function vensim_tool_command Lib "C:\Windows\System32\vendll32.dll" (ByVal Vcommand$, ByVal Vwindow As Long, ByVal iswip As Long) As Long
Yes, I'm using this code. and for first time , after I run the macro Vensim first page appears and then gives the same error.
"Vensim first page appears", do you mean the startup screen? If it does, then it should be working.
What error appears after the Vensim first page?
Yes, I mean startup screen.
this error:
this error:
- pic.jpg (19.58 KiB) Viewed 23507 times
Can you send me an email (vensim@vensim.com) with your Vensim serial number (click Help->About Vensim) and I'll try and get the correct DLL for you.
If you have the unlock code that would be better.
Tony:
I've just sent an email for you.
- Newbie
Tony,
i would like to access the following files uploaded but are unable to do so, im having the same issues with linking vensim and vba
would you mind uploading another copy of the following files:
Book2.xslm
2010-12-10 model.zip
model.rar
thank you
Book2.xslm
model.rar
thank you
The files download fine for me. Try a different browser.
