I am having trouble solving an issue related to time steps. I am mapping a production process where the input data is available on a monthly basis but the processing decisions are made on a daily basis.
My problem lies if I use a time step of one month the rates in the system do not react quickly enough to adjust for low inventories (an important measure) and I end up with negative stock. If I use a daily time step, the stock drifts downward instead of the needed sharp adjustment (another important measure).
I have a model in Vensim to explain this behavior if it would be of value.
Thank you for any help
