In PLE Plus it is possible to use aliasses for XLS files. Menu Model/Settings/XLS.
If the xls file is in the same directory as the model. no path is required.
But: if you use a path other than the modeldirectory, the model only looks in the modeldirectory and returns an error, not able to find the file in the model directory.
The workaround is obvious, the implications are annoying, always having to type thr full path name or alsways moving the xls file to the modeldirectory.
XLS references
XLS references
Frank Julsing
Frank Julsing
