running batch jobs
Posted: Sun Aug 08, 2004 9:43 am
by Almeida
I am running a model and there is a variable wich I need to change for different runs. It takes a lot of time changing this variable, running the model and repeating the operation for a new value. Has any one tried to automate this type of operation using Vensim PLE Pus?
Please any hints very much appreciated.
Posted: Sun Aug 08, 2004 10:01 am
You can try command scripts
http://www.vensim.com/documentation/html/25670.htm
Not sure if they work in PLE Plus though.
Maybe put the data in Excel, change there and run, that will be faster than editing an equation to change a data value.
[Edited on 8-8-2004 by Administrator]
Posted: Sun Aug 15, 2004 3:53 pm
by Rafael
You can try univariate sensitivity testing using the VECTOR distribution for the variable.
