sable demo problems
Posted: Tue Aug 17, 2004 8:45 pm
by afsinbulbul
I downloaded sable demo version to evaluate the software. It looks nice but it is so unstable. It is giving applciation errors so often. Is it a general case or is it only seen in demo version or is it an internal software conflict in my PC?
Posted: Tue Aug 17, 2004 9:24 pm
Do you have a managed PC? It could be that the files that need to be written to the windows system directory might not have been installed (this would cause problems).
I have uploaded a replacement installation that avoids this. Can ou try downloading again? The direct link is
http://www.ventanasystems.co.uk/Files/S ... oSetup.exe
Posted: Thu Aug 26, 2004 9:27 pm
by afsinbulbul
I downloaded it. Now some of the problems seemed to be solved (for example sable is not closing when I try to change the properties of a combo box) but the software is still unstable and closing itself pretty often. Also now I can not set the edit box to display in integer format. No matter which setting I choose it is getting to float again.
Posted: Thu Aug 26, 2004 9:37 pm
by afsinbulbul
this integer-float problem only happens when I choose "show spin control" option.
Also again with this option when you try to change the variable using the spin control it starts from 0 (even the initial value is something else).
Posted: Thu Aug 26, 2004 10:15 pm
by afsinbulbul
Another thing: With this version (.117) every time I try to close sable it is giving error and windows is shutting down sable.
Helpp.. :)
Posted: Fri Aug 27, 2004 12:18 am
by afsinbulbul
Sorry for consecutive questions but another thing I just noticed is now I can not open my file using the run time version. Run time version is .90 version and the developer demo version is .117. Is there a conflict between them?
Posted: Fri Aug 27, 2004 3:55 pm
.117 is updated so the file formats are different.
Can you send me the project you are using? It could be caused by a corrupt file.
This is a bug and will be fixed in the next maintenance release.
It sounds like the installation has gone wrong somehow. Can you zip the contents of your sable directory and email them to me?
Posted: Fri Aug 27, 2004 6:41 pm
by afsinbulbul
Well, then is there a run time version that I can use the open the .117 version project?
If I could do then my life would much easier I know; but unfortunately there is condifidential information in the model.Is there a specific file extension might cause this problem?Maybe I can check myself.
I attached it to this post. it is kinda big (>5mb). let's see if it'll go through.
A quick question: is there a way to navigate to a screen or mini screen based on the selection in a combo box?
Thanks again.
Posted: Mon Aug 30, 2004 1:55 pm
by afsinbulbul
I think first one missed attention, so here it is again:
It is biger than 5mb so I could no attach to this post.
Thanks again.
como puedo bajar SableDeveloperUpgradeSetup
Posted: Thu Mar 29, 2007 2:47 pm
by yeced
Por favor como puedo bajar SableDeveloperUpgradeSetup.exe de la pagina no bajarlo por favor si alguien me puede ayudar
gracias
