I'm using an 'if then else' statement to convert items of one type to another after a certain time. When I use different time steps, not all the items convert when the time hits 12 (works OK with 1, but not with 0.5 or 0.125).
Can anybody explain why they don't convert or what I'm doing wrong - model is attached.
Thanks,
Andrea
Time Steps and If then else
- Random_checks.mdl
- (2.12 KiB) Downloaded 884 times
I don't quite understand the question here. The model is working exactly as it should, you do the conversion when time >12, so at t=12, the conversion has not been done yet.
If you want the conversion to happen at t=12, drop the <= and use < instead.
type1 to type2 =
IF THEN ELSE ( Time < 12 , 0.01 , 1 )
Or have I misunderstood something?
type1 to type2 =
I understand.
have a look at
http://www.vensim.com/documentation/html/23395.htm
This explains Euler integration.
LEVELTime+TIME STEP = LEVELTime + TIME STEP * RATETime
As you have a time step of 1, everything is happening as you expect it to. Your "Conversion" parameter is not a rate (not time dependant), so when the time step changes, the calculation in the level changes as well.
Change your "conversion" parameter to be a rate, eg
conversion[TYPE1] = ( TYPE 2 TO TYPE 1 * Number[TYPE2] - type1 to type2 * Number[TYPE1] ) / TIME STEP
and that should have the desired effect.
I would also suggest putting units in for your parameters, a units check would have told you that "conversion" needed to be dmnl/month and not dmnl.
Hope this makes sense.
have a look at
Is there any way of having the change from type 1 to type 2 as a constant per month?
When I put the units as dmsl/month (and change the units of conversion), I get the problem that not all the items convert from one type to the other at the specified time for different time steps.
(Model adjusted and attached)
- Random_checks.mdl
- (2.39 KiB) Downloaded 830 times
If you want to instantly change the amount, make sure you divede this by time step. This way it will all be done during one time step and not one time period (e.g. month or day). See also Tony's comment.
I changed the if then else construction a bit so it will work. The first part is time step independent, the second part isn't. See adjusted mdl.
Jeroen
Jeroen
- Random_checks_JP.mdl
- (2.53 KiB) Downloaded 764 times
