What is the defferences between use look up and auxiliaty with look up?
I want to multiply a look up with other cariable, how can I do it?
lookup and with lookup
Reply diffrence between lookup and auxiliary lookup l
The two type of lookups are roughly the same. The constant lookup is a lookup function that needs an argument to generate a value. The auxiliary lookup is a lookup where the argument is already settled in the definition of the auxiliary.
See the simplistic model joined. When you put different values to the constant you will see that the lookup and the auxiliary lookup will give exactly the same results.
J.J. Laublé
J.J. Laublé
- lookup.mdl
- (2.06 KiB) Downloaded 634 times
