integration techniques
_Cristina_
Post by _Cristina_ »
Hello!
I'm starting to use Vensim PLE but I have some problems.
I don't know how to select an Integration Technique.
Can someone help me?
Thanks,
Cristina
I do not have the PLE Version, but it should be automacically set to the Euler integration technique that is the simpler.
However if you have to choose, choose the Euler one if you are a beginner.
J.J. Laublé
tymoignee
Post by tymoignee »
You need to click on "set" (for setting a simulation) and then on the left you will see "Euler" written. By clicking on "Euler" you can switch to "RK4." This is the only other method available in PLE Plus.
