integration techniques
Posted: Sat Feb 19, 2005 12:35 pm
by _Cristina_
Hello!
I'm starting to use Vensim PLE but I have some problems.
I don't know how to select an Integration Technique.
Can someone help me?
Thanks,
Cristina
Posted: Sat Feb 19, 2005 2:50 pm
by LAUJJL
I do not have the PLE Version, but it should be automacically set to the Euler integration technique that is the simpler.
However if you have to choose, choose the Euler one if you are a beginner.
J.J. Laublé
Posted: Sat Feb 19, 2005 8:44 pm
by tymoignee
You need to click on "set" (for setting a simulation) and then on the left you will see "Euler" written. By clicking on "Euler" you can switch to "RK4." This is the only other method available in PLE Plus.
