Hi Everyone,
Vensim 5.5a is now avialble for download. If you downloaded 5.5 I strongly recommend that you switch to 5.5a because of the problems discovered in 5.5.
Note: There was a backward compatability problem with 5.5 - variables would lose their shapes when opened in earlier versions of Vensim. To correct this open the model in 5.5a and save it. If the model is a .vmf model you will need to do a Reform/Clean.
Vensim 5.5a Now Available
