Simulation results change in PLE and DSS
LBD
Post by LBD »
Hello everyone,
I have been trying to run a simulation, but i get different graphs/results in PLE and DSS. What is seen as a proper graph to the equations in PLE is seen as a straight line in DSS. Is it possible for this to happen? If so, how can I make the DSS version display the right graph. I have made sure that it is the same file, both the versions are trying to simulate.
Please advice.
Both should give the same results. You do get constant graphs if you use Save Lists in DSS that don't include the variable. If you aren't doing that post the model and I will take a look.
LBD
Post by LBD »
Thanks Bob for the previous reply. It versions started showing the same results all by themselves. if i ever do have a problem again, I will post the model.
