I'm a new user of Vensim. I'm trying to create a model that should simulate a year on a hour by hour basis.
I have tried to create some lookup variable with 8760 time step. Every time I do this, I get this error message:
"Memory allocation failure - subblock"
Then a message with "aborting Vensim" appears and the program close down.
Why is this? I have tried to create lookups with only 4000 steps and this doesn’t appear to be a problem. Isn’t Vensim able to handle more than this?
If you could tell me how to overcome this problem I would really appreciate it.
Best regards,
Skjold from DK
Timesteps and lookups
time steps
Hi Skjold
If you have Vensim pro you can try something like the model joined.
- calendar.mdl
- (1.8 KiB) Downloaded 424 times
