import XLS from multiple rows
Olger
Post by Olger »
I have a question. I need to import data from excel to vensim. But it's devided in 2 rows (later it will be more if possible) One row is for he input of 2005 and the other row for 2006.
I don't want to paste them into one big row (this would be to long)
Which command do I have to use?
I have included a xls file for example, the 2 columns should be the input for vensim
[Edited on 6-22-2006 by Olger]
Input.xls
(16.5 KiB) Downloaded 336 times
There are a couple of ways to approach this.
The best is probably to write some macros in excel that manipulate the data into a single column.
Alternatively you can read each column as a data variable, then time shift them and add them up. The attached model does this. Note the use of :RAW:. This example does not work if TIME STEP is not 1 since the variable I called "data" is not really data.
input.mdl
(1.59 KiB) Downloaded 338 times
