IF THEN ELSE Qns
Seikyo
IF THEN ELSE Qns
Post by Seikyo »
Just wondering, how do we formulate a double IF THEN ELSE condition? For example,
Before time x, the value is x,
After time x, the value is STEP(y,<Time X>),
Then after time z, the value is change to STEP(z, <time z>)
is it possible to write equation like other programming language
IF <Condition> Then <Value X>
IF <Condition> Then <Value Y>
Else <Value Z>
You can nest IF THEN ELSE statements, but it does make the equations harder to read (I try to avoid them unless it is absolutly necessary).
IF THEN ELSE ( time < A
, condition A
, IF THEN ELSE ( time < B
, condition B
, condition C )
Seikyo
Post by Seikyo »
Thanks. That is the syntax I am looking for. I am still figuring out ways to avoid it.
nested if then else
To avoid the syntax, the solution is to use intermediary variables.
If then else (A < B,C,D),
D = if then esle (X >Y,E,F)
It reduces the complexity of the equations but increases the
complexity of the sketch.
If I cannot avoid nesting IF THEN ELSE, I do something like the following.
Some result =
IF THEN ELSE ( time < A , condition A , 0 )
+ IF THEN ELSE ( time >= A :AND: time < B , condition B , 0 )
+ IF THEN ELSE ( time >= B :AND: time < C , condition C , 0 )
+ IF THEN ELSE ( time >= C :AND: time < D , condition C , 0 )
As long as you are careful and make sure each condition can only happen by itself, it makes things a little easier to read. It does for me anyway.
rdudley
Post by rdudley »
But I think that the point is not only to avoid _nesting_ If then else statememts, but to avoid USING them in the first place.
If you have lots of if then else statements you should probably think about using a different modeling approach.
I normally use them only to turn on or off effects from selected parts of the model.
R. G. Dudley
