i have a big problem.
my model is about a inventory model.
at the time (t), i have to do two things, one is to check do i have the receiving , if i have, i need to add the receiving quantity to the inventory. then to check do i have to place the replenishment order, the other thing is to do the customer demand,( to minus the customer demand.)
i am confused about the order in vensim, and how to set up it?
summary: i have to check do i have the receiving at time t, then to check do i have the replenishment order, then to check the custome's demand .
and
how to figure it out
A simple formulation is below - the molecules show better ones. See also books on System Dynamics such as Sterman's text.
Inventory = INTEG(receipts - shipment,initial inventory)
receipts = other formula
shipments = MIN((inventory + TIME STEP*receipts)/min order fill time,orders)
min order fill time = TIME STEP
what dose time step means?
when do i need to use it in my model?
when i set up a model, i always fact the unit problems,
such as, if invetory is a level (case), customer demand is a Aux(case), and sales(case/day) is Min(inventory, customer demand), i will see the unit wrong message, How to figure it out?
attachment is my practice model.
how to set up the units in vensim
the attachment...
thank you .
thank you .
- 1.mdl
- (1.74 KiB) Downloaded 357 times
