what does time step mean
sally
Post by sally »
when do i need to use time step in my model?
when i set up a model, i always fact the unit problems,
such as, if invetory is a level (case), customer demand is a Aux(case), and sales(case/day) is Min(inventory, customer demand), i will see the unit wrong message, How to figure it out?
attachment is my practice model.
hope someone can give me suggestion...
thank you
1.mdl
(1.74 KiB) Downloaded 430 times
time step
joined the model 2 that is right
2.mdl
(1.65 KiB) Downloaded 418 times
sally
Post by sally »
hi,
thank you for your help. but i am confused about " sales rate=MIN(inventory/delivery time, customer demand).
what's the difference between above and "sales rate=MIN(inventory, customer demand)/delivery time....
thank you ..:D
time step
Another more appropriate model, deals with the time step and not the time delivery is the model 3 joined.
You should study the Vensim\models\guide\chapter3, where you find inventory models.
You can find too plenty of inventory in other models too.
3.mdl
(1.64 KiB) Downloaded 422 times
Hi Sally,
is dimensionally inconsistent - demand is widget/month so that demand/deliverytime would be widgets/month/month which makes no sense. inventory/deliverytime converts the stock inventory to a flow. If you can work through a few chapters of a text book on system dynamics it will likely be very helpful.
sally
Post by sally »
i will work through sterman's book ,
hope i can learn more...
thank you
