if demand is a distribution
sally
Post by sally »
hello,
i have a problem,
if i want to simulate a event for 100 days,
and i have a variable "demand", i want to set it as a normal distribution in the whole period....it means the demand is start at 0, and have the highest in the middle time, then in the end(100) is 0,
how to set this up ?
hope you can know my meanings...
thank you ..
nikvyas
Post by nikvyas »
There is already a function for Normal distribution (as well as other distributions) called RANDOM NORMAL
sally
Post by sally »
but
when i use normal distribution
it means the demand is a normal,,
not like the attachment..
attachment 1 is the one when i use normal distribution
and the attachment 2 , in the graph,,,,the figure is the one which i want to have .
hope some one can help me
sally
attahment
Post by sally »
fyi
2.mdl
(2.14 KiB) Downloaded 642 times
Can you post the attachments you mention?
I am not sure what you are after but you can use
normal val of x = 1/sqrt(2*3.14)*exp(-x^2/2)
x = Time
sally
Post by sally »
does it mean i have to set up a variable name x
then to key in the formula?
sally
Post by sally »
sorry, i have try it ,,
but it not what i want
my hope is " in my simulate time(100weeks), my deamnd's figure is like the normal distribution
so , at frist , the demand is low,,in the middle time,,,demand is on the top,,,and ,,,in the end, deamnd is become small...
pls, hope some one can help me
