lookup function
VIVIV
lookup function
Post by VIVIV »
i have a problem about look up function
i don't know how to use it ?
although i have read the vensim mannual
still didn't work..
hope someone can help me
thank you
malli
Post by malli »
It might help if you post your model if its about how to do it in Vensim.
If your question pertains to the conceptual aspect of formulating lookup functions, there are a couple of resources that might help-
1. If you have access to John Sterman's book - check up chapter 14
2. Another excellent resource is Roadmaps. There are two good articles on formulating table functions - this is the link.
http://sysdyn.clexchange.org/sdep/Roadm ... D-4865.pdf
http://sysdyn.clexchange.org/sdep/Roadm ... 4653-2.pdf
Malli
Lookups are quite easy to use.
Here is a lookup definition (only two points, 0,10 and 1,100)
LOOKUP GRAPH ((0,10), (1,100))
To use,
Y = LOOKUP GRAPH(X)
for X=0, Y will be 10, for X=1, Y will be 100.
Hope this helps.
VIVIV
model attachment
Post by VIVIV »
hi,,
i hope customer is the lookup
how to use it
2.mdl
(2.57 KiB) Downloaded 465 times
