I have built a client model which pulls in data from an Excel spreadsheet using GET XLS DATA and GET XLS CONSTANTS using Names in the formulae - works very well.
I now want to make the model multi-dimensional using subscripts
Please advise or point me in the right direction in order to determine:
1. How to format the subscripted time series data and constants in the spreadsheet
2. How to name the subscripted data in the spreadsheet - ie do you need to create a name for each separate data item or just the first cell in a suitably formatted table
Many thanks
Roger
[Edited on 2-5-2007 by impactdynamics]
Subscript Data From Spreadsheets
Roger,
I have attached an example model pulling data from a spreadsheet into subscripted variables and also using named ranges. I will post the accompanying spreadsheet in the next post.
You will see in the example that Demand, Supply Available and Priority are read from the spreadsheet and are subscripted. My preferred method is to create a single named range in Excel for all elements of a single subscripted constant, although the manual also suggests entering a reference to the first cell only.
Hope this helps
Lee
Hope this helps
Lee
- Allocate_with_xls.mdl
- (6.57 KiB) Downloaded 648 times
.. and here is the excel data file for the sample model.
Lee
Lee
- xlsdatafile.xls
- (16 KiB) Downloaded 466 times
Thanks Lee
yes it does - thanks
Please see marked up spreadsheet with call out questions
Rog
Rog
- xlsdatafile_rd.xls
- (16.5 KiB) Downloaded 425 times
thanks Lee - this is great
Now the Vensim model makes it much clearer.
It gives me a great start - I shall experiment with this
What is the significance of the ? in '?data.xls' - I thought you needed the whole filename ie 'xlsdatafile.xls' - is this some kind of useful shorthand?
Does the datafile always have to be in the same directory as the model?
What do you do if you need 3 dimensional data - as I do - Region-Inspection-Resource?
What would the Time Series Demand array look like if you wanted another dimension on it eg Demand for each region?
Many thanks again
Rog
Many thanks again
Rog
data.xls is a placeholder reference to the actual xls file used by the model (hence the "?").Originally posted by impactdynamics
Rog
Go to menu option model>settings>xlsfiles and enter "Data" in the "For the reference" field (no need to enter a "?" char). Then select the actual spreadsheet to refer to. This approach means that if you change the spreadsheet name you don't have to modify all the equations using getxls functions.
Also, there is no requirement to have the spreadsheet in the same directory as the model.
Just seen this. In my preferred method, all cells covering data for a single subscripted array are named (have a look at the named ranges already entered in the spreadsheet). So, for example, in the Demand section, the cells containing the figures 500, 300 and 750 have been grouped and named "Demand" for reference in the relevant GET_XLS_CONSTANTS function in the Vensim model.
