what is Forecast and Smooth function mean
sally
Post by sally »
i need to use a function to forecast,,,,i don't know which function is suitable, i check the vensim, there are two functions i think are suitable, but i didn't know what does it mean, such as, Smooth function=SMOOTH(units,time) , what is time meansi in this equation, i don't know what should i set it , hope some one can give me some suggestions.
thank you ...
forecast.mdl
(2.3 KiB) Downloaded 710 times
sally
Post by sally »
i still didn't know what is smooth function means?
i have check the help- it said, it is a expo. smooth forecast way, but i don't know how to use it, because in expo. smoothing way, it has the alpha value, and you can control it or revised it, but in smooth function , i can't set up the alpha value?
how to do it
hope someone can help me...
you should read Sterman's book, business dynamics.
There is a chapter on forecasting, that explains the trend and forecast function.
The preceding chapters should be studied too.
malli
Re:Smooth
Post by malli »
Find attached a model file that shows how smooth works. I have provided two examples -
1. Doing a smooth without using the vensim formula
2. Doing a smooth with the vensim formula
Hope this helps. Would second what JJ has written - do read Sterman on this.
Regards
Malli
smooth_example.mdl
(3.17 KiB) Downloaded 919 times
sally
Post by sally »
hi
thank you for your help, i will read Sterman's book..
