what is Forecast and Smooth function mean
Posted: Fri Feb 16, 2007 2:25 am
by sally
i need to use a function to forecast,,,,i don't know which function is suitable, i check the vensim, there are two functions i think are suitable, but i didn't know what does it mean, such as, Smooth function=SMOOTH(units,time) , what is time meansi in this equation, i don't know what should i set it , hope some one can give me some suggestions.
thank you ...
Posted: Sat Mar 03, 2007 2:34 am
by sally
i still didn't know what is smooth function means?
i have check the help- it said, it is a expo. smooth forecast way, but i don't know how to use it, because in expo. smoothing way, it has the alpha value, and you can control it or revised it, but in smooth function , i can't set up the alpha value?
how to do it
hope someone can help me...
Posted: Sat Mar 03, 2007 10:04 am
by LAUJJL
you should read Sterman's book, business dynamics.
There is a chapter on forecasting, that explains the trend and forecast function.
The preceding chapters should be studied too.
Re:Smooth
Posted: Mon Mar 05, 2007 5:15 am
by malli
Find attached a model file that shows how smooth works. I have provided two examples -
1. Doing a smooth without using the vensim formula
2. Doing a smooth with the vensim formula
Hope this helps. Would second what JJ has written - do read Sterman on this.
Regards
Malli
Posted: Mon Mar 05, 2007 7:59 am
by sally
hi
thank you for your help, i will read Sterman's book..
