Moderator: Administrator
pz
Posts: 27 Joined: Thu May 06, 2004 5:33 pm
Post
by pz » Fri May 04, 2007 10:00 am
How can I show the values the slider points to?
Thanks, Paolo.
pz
Post
by pz » Fri May 04, 2007 11:05 am
One way is - I see now - to use an "edit" control, disable it, and link it to the same parameter the slider is linked to. This way the edit box shows the current value set by the slider itself.
Is there any simpler way to get the same result?
Posts: 4596 Joined: Wed Mar 05, 2003 3:10 am
Post
by Administrator » Fri May 04, 2007 12:20 pm
You can put some static text on the screen, make the text like
@VENSIM PARAMETER@
and it will show the value of the parameter. If the slider is showing "percentage complete" you would have static text with
@percentage complete@
pz
Post
by pz » Fri May 04, 2007 12:25 pm
Nice. Tnx
