forecasting a demand
Mikka
Newbie
Post by Mikka »
hi!
I want to forecast a demand in vensim. My demand function is a mix out of 4 different funtions (see attachment). What is the best way to do it?
demand_abcd.mdl
(4.67 KiB) Downloaded 326 times
The best forecast for a random variable is the mean value. The other inputs are all deterministic so you can just shift them in time to get the forecast. Alternatively just use the SMOOTH function - it will miss the trend but basically behaves quite well with all other inputs (unless pulses or cycles are deterministic).
