vensim & DLL
Posted: Sat Jul 14, 2007 2:52 pm
by gk720421
I use c++ to make a DLL(Fej1023). I want use the DLL in vensim,but the result isn't the same.
I declare several variables in C code to replace variables in vensim , for example: 'double groundW' is computed, and I write functions to show it and the count result in the same interface in vensim , but the 'groundW' and 'gaW' are just out of my expect , become very huge , at first I think it's the problem of over flow , but I find the difference is the same , for each time I enter the same input .
for example , if enter 180 in 'need' of the vensim interface and u enter 180 again , u'll find that the difference of groundW of two times is 8000 , but the number of groundW should be the same if u key in the same 'need' .
thank you for help !(append file is the C code and vensim file)
[Edited on 7-15-2007 by gk720421]
Posted: Sat Jul 14, 2007 5:43 pm
I cannot work out what you are trying to do here. All I can really suggest is stepping through the C code using the debugger and see what values Vensim is passing to the DLL. Make sure it is calculating what you expect it to.
All the best,
Posted: Sun Jul 15, 2007 3:50 am
by gk720421
I send the DLL . you can include it in my vensim.
Please help me,thanks.
Posted: Sun Jul 15, 2007 2:15 pm
I was able to build the DLL fine and step through the code using the debugger, I just cannot figure out what you are trying to do.
All the best,
Posted: Sun Jul 15, 2007 3:00 pm
by gk720421
ok! thank you~
I meen I use the "fej1023. dll" in "example1" VS. I don't use it in "oriange"
I find the final answers(supply2) are different , I don't know what is wrong.
Posted: Sun Jul 15, 2007 7:58 pm
There must be an error in your C code if it is not giving the same answer as you expect. Have you stepped through the code in the debugger to check it is doing what you want?
Posted: Mon Jul 16, 2007 8:56 am
by gk720421
1. I find that at first when I use "Run a Simulation" in example01(with fej1023.dll) VS. oriange
,and the final supply2's answers are correct.
2. If I input other number in "need" in example01 . I must close it, open the example01 again
the supply2' answer VS. oriange is the same.
3. But I find if I can't use "Automatically simulate on change" in 'example01' and 'oriange'
because the final supply2's answers are different.
I don't know what' wrong
Posted: Mon Jul 16, 2007 10:42 am
Do you need to reset the internal variables in the DLL?
static long double groundW=50;
static long double inflow2=20;
static long double gaw=0;
Use the function
CFUNCTION int PASCAL simulation_setup(int iniflag)
groundW=50;
inflow2=20;
gaw=0;
return(1) ;
Does this now give you what you need?
Posted: Mon Jul 16, 2007 5:51 pm
by gk720421
thank you for tell me this information , but I am still testing the code ,
after using the code you give me , the variabls is not jumping any more,
but the result is not right still .
Posted: Mon Jul 16, 2007 9:43 pm
>> the code , after using the code you give me , the variabls
>> is not jumping any more, but the result is not right still .
The problem is in your C code, you need to step through it using the debugger and make sure it is doing what you need it to.
