Multiple usage of identical table-function
gyucel
Post by gyucel »
In a model currently I am working on, I am willing to use an identical non-linear function between several variable couples.
Is it possible to define this function once, maybe as a built-in function of vensim, and then use it in multiple points?
Let's call the function f. What I want to learn is to define f once, and then define the relationship among several couples as this;
a=f(b)
c=f(d)
e=f(g), etc.
If it is not possible, it seems that I have to redefine the same table function for each couple in the example given above. Am I right?
cheers,
gonenc
multiple use of tble functions
It is of course possible.
Here is an example joined.
multiple use.mdl
(1.73 KiB) Downloaded 508 times
gyucel
Post by gyucel »
Thanks Jean-Jacques
