I'm new to Vensim and was wondering if anyone had tips on general formatting issues. For instance, in trying to connect one rate to another, I can't seem to move the name of the rate without moving the whole thing. Also, if I want to have 2 flows coming out of 1 stock, can I have both coming out of the side or does one need to be out of the side and one from the top or bottom? I attached an example model that has the problems I'm referring to. Any help is much appreciated!
Heather
Vensim model formatting
- forum sample.mdl
- (3.71 KiB) Downloaded 404 times
I would not make a rate depend from another rate, for clarity reasons.
I would prefer define one or some intermediate auxiliaries and make the different rates depend on the auxiliaries.
In my models, the only action of the rates is to feed or decrease stocks, they do not have an influence on anything else.
But the administrators know if it is a good practice to make a rate depend from another one.
For clarity rates are named directly so that moving the valve also moves the name of the rate. You can also use an unnamed rate (create a rate then press the Esc key instead of filling in the name) and connect other variables to that.
Connecting a rate to another rate is, as JJ has stated, done only very rarely. The gravity model in the samples show this, but beyond physical acceleration and velocity I have never made use of a rate connected to a rate.
As far as multiple rates coming out - this is whatever you want. Running two in parallel is common and often done by putting attaching the name of the rate on the top flow to the top of the valve (right click on the valve).
