I’m using version 5.7 of the software.
I have set up and equivalence (Drug,toDrug) and I have a variable called switch grid which is arrayed by two subscripts Drug, and its equivalence toDrug. When I sum across or down I get the expected answer. However, when I multiply this variable by any constant I get "0" for the answer across all dimensions. Also, when I normalize this variable in another variable I also get "0" values in each subscripted output. Any idea as to what is causing this?
subscript equivalence
Try the attached model. Just needed to change some of the equations so that they had both [drug,todrug] instead of [drug,drug].
For example,
switch grid numbers[drug,todrug] = CONSTANT*SWITCH GRID[drug,drug]
was being calculated as
switch grid numbers[A,todrug] = CONSTANT*SWITCH GRID[A,A]
switch grid numbers[B,todrug] = CONSTANT*SWITCH GRID[B,B]
switch grid numbers[C,todrug] = CONSTANT*SWITCH GRID[C,C]
You need to include todrug on the right hand side of the equation to pick up the correct subscripts.
Hope this makes sense.
[Edited on 17-10-2007 by Administrator]
For example,
- experiment_01.mdl
- (2.21 KiB) Downloaded 314 times
Thanks for your help!
