Monod type differenctial equations
I having a problem with unit check on a differential equation i am trying to test.
Attached is the workbench for the model
- Compost1.mdl
- (1.72 KiB) Downloaded 479 times
I am not sure what the question is - the model has as yet no units or equations. Biomass should probably be in Kg or Tonne - and its temperature determined by ambient temp and internal organic activity. The equations and units for the internal organic activity are beyond me (my compost piles never work right). But you probably want the equivalent of population (a level) for different organisms consuming different types of organic materials (levels) in order to create new ones (also levels). The temperature change is then determined by the activities of the bacteria and other consumers relative to the total mass.
I hope that is helpful.
I have detailed the equation as mush as possible. The temperature terms have been left out to make it look simple, although temperature is affecting the microbial growth rates. The units have also been attached although, i tried to use a simpler unit system.
Home it meet you interest to discuss or make your contribution.
Best regards
Best regards
- Compost substrate.doc
- (20.5 KiB) Downloaded 480 times
Dear Bob,
I could assume that CO2 should also have a d/dt. how do i represent such a flow system. Also CO2 feeds equation 7 in the attached document which explains the conceptual model. I which to keep temperature(T) constant for the time being.
Even without the CO2 equation incorporated, i am realizing high explosion of X (mesophilic and Thermophilic), coupled with a negative S
hope to here from you.
Dear Bob,
- CONCEPTUAL MODEL FOR SYSTEM- VENSIM.doc
- (55 KiB) Downloaded 564 times
Dear Bob,
You are right in this respect, and that is what I have been doing. Unfortunately, the values keep exploding in both the negative and positive directions. I will keep trying.
[Edited on 5-16-2008 by grockson]
- Compost2.mdl
- (6.21 KiB) Downloaded 505 times
