vdi-file
mruud
vdi-file
Post by mruud »
What would be the VENAPPS command to load a vdi-file?
Use the SIMULATE>READCIN or SIMULATE>ADDCIN to add the vdi file. The vdi file will also be loaded if it is in the list of changes files (existing or set via SIMULATE>CHGFILE) and READCIN is not called but this is path dependent so it needs to be used carefully.
