Hello everybody,
working the first time on a small model (actually an assignment) I struggle with getting the lookup function smoothly into the model.
The error message in the very function while editing (see attached screenshot) reads as:
"table of Effect of Resources on Life Span is a lookup name or stringvar and cannot be used as a variable."
I tried to embedd the lookup into the auxilary variable "Effect of Resources on Life Span" - not to the better;-(
To be honest I am clueless what it means and whether the lookup function / table is in the right place/use.
Help is very much appreciated.
Best regards
Ralf
Lookup function - error message and no clue
- 081012_Loopup_Function.png (22.88 KiB) Viewed 3144 times
Ralf Lippold
I guess is that what you are trying to do is
Effect of resources on life span =
Table of Effect of resources on life span ( Fish/resource limit )
See also the following
http://www.vensim.com/documentation/html/22820.htm
Hope this helps.
Hope this helps.
Hi Tony,
Thanks that's it:-))
Best regards
Ralf
Best regards
Ralf
Ralf Lippold
