DICE model
duilio
DICE model
Post by duilio »
Hi Bob, all
apologize for bothering,
I've got the DICE Model from Tom Fiddaman's web site but for some reasons I wasn't able to run it. It seems that it cannot "see" the external data, but the data are there.
Can you help me?
Thanks in advance!!
G
DICE4.MDL
(43.59 KiB) Downloaded 96 times
In Vensim, click "Model->Import Dataset".
Select the file "NORDDAT2.DAT" and click "Open".
You might get a message "Dataset NORDDAT2 already exists. Do you want to overwrite it?". Click "Yes".
Hopefully you will get the message "Conversion completed without error".
Now click on "Model->Simulate".
Click the "Advanced" tab.
Click the "Data Sources..." button and select "NORDDAT2.VDF".
Click the "Simulate" button.
Hope this helps. The model and all files were prepared a long time ago so file formats have probably changed since then.
duilio
DICE Model
Post by duilio »
Hi Tony,
that's exactly what I did.
But I've got two error messages:
ERROR: The variable Emiss Stabilization - and perhaps others require a data file be specified
ERROR: Unable to correctly load in exogenous values - aborting
Should I have to re.build the model from scratch?
In this case is there anybody who can give some hints (at request, when I'll have questions...)
Thanks in advance
G
Has the data imported correctly?
The error suggests you have missed the following steps.
duilio
DICE Model
Post by duilio »
Hi Tony,
I did it, I've added the data source on the advanced tab, the error is still there.
It seems there is something corrupted in my version, maybe problem of Windows, it can be everything...
Btw I'm trying to replicate the model from scratch, we will see what happens.
G
Did the dataset import correctly?
I followed those steps again just to check if I had missed anything, it worked fine for me.
duilio
DICE MODEL Again: I need help
Post by duilio »
Hi Tony, all
I had to re-build the model from scratch, I did all the necessary steps you described but the model did not work. Maybe I lack some fixed to the software. Anyway, Now I have a working model. I still have to add the equations that use subscripts.
So I need help in understanding the use of subscript sin this model. What 's the meaning of the equations in the subscript (T1-T10) ? Particularly what is the purpose of the T subscript in this specific model?
Apologize for asking a narrow question, but I need to understand it...
Thanks a lot in advance
G;)
The T subscript is used to implement policies at different times (ie 1965, 1985, 1995, 2000...). The model uses SHIFT IF TRUE to move through the different times - eg
Shift Red = SHIFT IF TRUE(GHG Red Fracs[T1],shift switch=1,T10,0,GHG Red Fracs [T1])
This is a clever, but confusing, way to implement this. It could more easily be done with VECTOR LOOKUP but that function was not available when the model was written.
duilio
DICE Model
Post by duilio »
Thanks!!
G
duilio
DICE Model, last question for Today...
Post by duilio »
Guys,
If I want to optimize the Discounted Utility which type of contraint should I have to set - up in the payoff definition?
Is it a contraint strictly needed for this optimization?
Thanks a lot!
G
Constraints do not go in the payoff function but in the range for the search variables. For example if you are searching over a faction it will usually need to be between 0 and 1. For the payoff you just need discounted utility with a weight of 1. The payoff computation accumulates this.
