cohort with SHIFT IF TRUE
geamaro
Post by geamaro »
Does anybody have a model that uses cohort with SHIFT IF TRUE to be used as an example? TIA.
The attached is a relatively simple demographic model demonstrating 1 year age cohorts - also it has a population pyramid graph which is useful for looking at the evolution of age distribution. (by the way dgraph is short for demographic).
dgraph0.mdl
(4.83 KiB) Downloaded 379 times
cohort with shift if true
Hi Bob
I tried to see how the graph on the model joined was constructed, but it seems to be a special graph that cannot be modified or viewed using the standard building graphs tool.
How is it possible to understand the building of such a graph?
geamaro
Post by geamaro »
Thank you Bob for your help!
G
To look at the graph definitions use Save As from the Graphs tab of the control panel then open the .vgd file in a text editor.
programming a graph definition
Hi Bob
Thank you for the information.
I did not know that is was possible to program custom graphs!
