Custom Graph with thicker lines
Travis
Post by Travis »
I would like to have all the lines in a graph be "thick", say a line width of 2 or 3. I know there is a Vensim pref for Thick Lines, but that doesn't make them all the same thickness. Is there a way to 1) modify the Graph tool or 2) create a custom graph that loads all the current datasets instead of the top-most? The documentation says it only loads the top-most, which is the behavior I see too.
You can set line thickness on custom graphs by filling in the LineW box.
The custom graph by default displays the first loaded dataset. If you go to Tools>Options>Settings you can change Load Dataset in Position and change First to Last. I will look into having a convention for the last loaded dataset.
Travis
Post by Travis »
Maybe I should rephrase my questions: How do I get a graph off all loaded datasets such that all line widths=2? Which datasets are plotted should only be the active and should change.
Just use wildcards (*1, *2, *3, *4, *5, *6) for all the runs you might load - only the runs actually loaded will be graphed.
