How can I run a model in vpm format
Posted: Fri Dec 12, 2008 7:37 am
by duilio
I've got a model in vpm format (from Tom Fiddaman's web site) but I don't know how to run it.
I have a Vensim DSS version (a little older, boufgt about 4-5 years ago).
Can you help me?
Thanks a lot
G
Vpm format
Posted: Fri Dec 12, 2008 11:40 am
by LAUJJL
I tried to unload one of the file from Tom Fiddaman'é web site.
Il worked well if I opened it directly, but did not when I unloaded it and tried to run it from the unloaded version.
The data file was missing.
In fact when you unload the model you must precise the format of the model and add .vmf to the name of the file.
Othewise it names the model .mdl and it does not find the data file. I suppose that the .vmf format has the data included in it.
If you load it as .vmf unless there exist a version problem.
you version maybe cannot run packed models.
In my latest version you can run it.
[Edited on 12-12-2008 by LAUJJL]
Posted: Fri Dec 12, 2008 12:04 pm
by bob@vensim.com
You can download the Vensim Model Reader from vensim.com to run packaged models (or update). They will not run in older Vensim versions.
Posted: Tue Dec 16, 2008 8:14 am
by duilio
Hi there,
I've got the model reader, nice, but I need to see the equations (that's the reason why I've downloaded the model).
Is there a way to "port" the model so I can read the equation with my old VENSIM DSS ?
Thanks a lot for your help
G
Posted: Tue Dec 16, 2008 10:33 am
by duilio
Hi all,
should I have to assume that there's no way to do that ?
So the only chance is getting the thesis and replicating the model ?
Thanks a lot
G:)
Posted: Tue Dec 16, 2008 12:12 pm
by bob@vensim.com
To see equations in the Vensim Model Reader use one of the two document tools in the analysis toolbar on the left. The upper one shows the equation of the currently selected workbench variable, the lower all equations.
Posted: Tue Dec 16, 2008 1:28 pm
by duilio
Great!
Thanks a lot Bob!
G
