haruki
Post
by haruki »
If I have a graph and I only want to fetch the data from it each third steps. what kind of function could do this?
Example..
Graph
1=5
2=3
3=8
4=3
5=2
6=21
7=8
8=6
9=19
This means i want to get the following result
0, 0, 8, 0, 0, 21, 0, 0, 19 (each third step, get value from graph).
Anyone?
Sincerely,
Peter
Post
by Administrator »
Have a look at the modulo function, and then use an IF THEN ELSE statement. Using a combination of the two you can do this quite easily.
Hope this helps.
haruki
Post
by haruki »
Hm, could you give me an example how you mean?
haruki
Post
by haruki »
Nevermind, got it to work.
Thnx..
IF THEN ELSE(MODULO(Time, 4)=0, X, 0)
