Hey all!
I'm a newbie to system dynamics and I'm learning how to use VenSim PLE. One question that has been bothering me is about negative stocks. Can I use this kind of an equation to prevent the stock from going negative:
IF THEN ELSE(outflow rate > stock, stock, outflow rate)
I believe that the flows are always related to time, but the stocks aren't. So can I compare the values of rates to the values of stocks? If this is not possible, how could it be done?
Thanks a lot for your help!
- julppu
Preventing negative stocks with IF THEN ELSE
