Fudge Factors, Units of Measure.
karankhosla
Post by karankhosla »
Greetings!
Could someone please help me understand why Vensim gives me an error for units of measure when I want to use equations such as the following:
Price = 10-0.00794*Q
Units of Measure that I would like in the model:
Q = {Units}, Price = {$/Month}
Vensim will not give me a clear on the Units Check for this formula, unless I add the following fudge factors to get Price in {$/Month}:
Price = 10-0.00794*(Q/(NORMAL Q*NORMAL Q)*NORMAL P)
Where:
NORMAL Q = 1 {Units}, NORMAL P = 1 {$/Month}
If you see the model attached for maximizing profits in a monopolistic firm, there are other problems; for example, I must have a dimensionless argument before I use a "power operator", Q^2, must be (Q/NORMAL Q)^2 in order to get through the units-check.
I don't want to compromise on my units!
Thank you very much!
ProfitMaxMonoply.mdl
(5.57 KiB) Downloaded 277 times
Create two new constants (not sure what you should call them) and put the two numbers "10" and "0.00794" in them. Now give the constants the correct units and all should balance properly.
