Vensim graph tools in Sable.
Posted: Thu Aug 07, 2003 8:12 am
[ADMIN]Received via e-mail[ADMIN]
I am using the graph tools in sable. It is working very fine. But I have the following problem: I changed the font size of the title of the custom graphs in the vensim tools--> option menu. The new fonts are shown on the custom graphs when I open them from vensim. But the problem is that the new fonts do not show up when I open the graphs from Sable. My custom graphs on Sable keep showing the old fonts.
Posted: Thu Aug 07, 2003 8:13 am
To answer question the font information is stored in Vensim.ini - you can copy that from your windows directory and then use the Venapp command SPECIAL>READINI|vensim.ini to load that information. That should make the graphs appear the same.
Posted: Thu Aug 07, 2003 8:14 am
Just a quick addition to the reply.
If you copy the Vensim.ini file into the MODEL directory for Sable, it will be loaded automatically and have the correct fonts etc on the graph.
