refresh diagram model
Posted: Wed Jul 01, 2009 10:37 am
by francapitan2
Hello bob, I am Francisco (fracapitan2) and if you remember I was doing a program that it was handling vensim across commands.
I managed to publish both models and files vmf with your help. Nevertheless I had a problem.
When I use the version 5.9 everything it is OK but when I use the version 5.8 and 5.7 the following thing happens. After a file publishing if i want to open another model anyone my program don“t refreshes the graph nor the results; it is to say the commands vensim_show_sketch and other commands of obtaining response of vensim do not generate a current (actual) response and I do not know why?
With vensim 5.9 everything is OK but with vensim5.8 and 5.7 not
Do you Know?
Posted: Thu Jul 02, 2009 11:04 am
by bob@vensim.com
This is a problem that was fixed in 5.9, which is why the issue exists with earlier releases. If you are using work in progress graphs there are also problems in those in 5.9 that are fixed in 5.9c.
