Period of variable signal
yusuke
Post by yusuke »
Hello
I'm using vensim professional version.
I make a variable which has a signal "0" or "1".
For example (starttime =1 , endtime =10)
time 1 2 3 4 5 6 7 8 9 10
var 0 0 0 1 1 1 1 1 0 0
I want to get the period which var = 1.
In this case , time(8) - time(4)+1=5
It is the same of the count which var(value) =1
Thank you for your help.
Yusuke Tarumoto
The period of time since a variable last changed can be computed using
time unchanged = Time - last change time
last change time = SAMPLE IF TRUE(ABS(var-old var) > tolerance, var,Time,INITIAL TIME)
old var = SMOOTH(var,TIME STEP)
This will start counting again from 0 when the variable changes, so I am not sure if that is exactly what you want.
yusuke
Post by yusuke »
Thank you ,Bob.
I try to use [SAMPLE IF TRUE] function in a model.
But I can't. My troble is [last change time].
I attach a sample model .
Best regards
spanvalue.mdl
(2.2 KiB) Downloaded 287 times
The model does what I would expect it to. I think I do not understand what you want to see.
period of variable signal
If I understand what you want (hence the utility of being clear about what one wants), you are interested in knowing the number of periods where var is equal to 1?
If it is what you want, the model joined is extremely simple and does the job.
spanvalue[2].mdl
(2.05 KiB) Downloaded 253 times
yusuke
Post by yusuke »
Thank you LAUJJL .
Your model spanvalue[2] is just one i need.
The using of equation <Time Step>/<Time Step> is effective for unit check.
I thank bob , too.
