Hi colleagues, how to find atomatically moment of time when the stock is equal to 100 for example and use it (the moment of time as numerical value) in some calculations?
Thanks in advance
[Edited on 8-15-2009 by rosenm]
time
time
Here is a small model that makes the job, with no unit errors.
regards.
regards.
- model[2].mdl
- (2.04 KiB) Downloaded 447 times
Thank you very much for the answers, that is what I need, but "variable to be used if level is equal to 100" is a function of time and at each time step has different values, one of which is that I need (10 in this case, please see the attached picture).How to store this value (10 ) as a constant so it does not depend of the time?
[Edited on 8-18-2009 by rosenm]
[The extension wmf has been deactivated and can no longer be displayed.]
