almoon
Post
by almoon »
I draw several sketchs and when i need to see the equations it give me all the models equation so how can i see each sketch equation separately ?
Post
by Administrator »
If you use the document tool, there is an option here to only show the equations on the current view. Have you tried that?
almoon
Post
by almoon »
Thank you very much
when I press DOC option I got the following :
Display
Formatting
Multiple equations option
So what should i choose from each one to get what i want ?
Post
by Administrator »
In "Multiple equations options" there should be a tickbox for "vars in current view".
almoon
Post
by almoon »
I dont have this option so what shall i do ?
Post
by bob@vensim.com »
Select everything in the sketch and use Edit>Group and give a new group name. Then document that group (another document option).
almoon
Post
by almoon »
Yes it is work thank you veyr much
