Need help on Fractional Aircraft Ownership
toukairin
Post by toukairin »
Greetings,
I am currently doing a research for my final assignment, about Fractional Aircraft Ownership(FAO). If anybody's curious, yes, I'm widhie's junior (she posted 2 years ago on the similar-but-different-perpective topic).
Currently I'm working on the financial/economical side of the FAO. Here's some points about the topic I'm working on :
- We got ourselves two aircraft or more that is bought with money from many people, not just one person.
- The people who bought this planes together have the right to use the planes ASAP.
Now the "ASAP" here means that if there's a case of the one of the owners (Mr.X) said "I want to fly in 3 hours!", then the FMC (Fractional Management Company, the one who runs and maintain the aircraft) have to provide the plane at all cost, either with the plane owned by Mr. X (and his partners), other aircraft in the FMC's inventory, and the last resort is to charter an aircraft from another company (very expensive).
- The number of flight hours per year that an owner can use is limited to the share he bought. According to the earlier research, it is between 1/16 (about 50hrs) and 3/8 (about 300hrs).
- The financial and economic calculations in this final assigment are limited to revenue analysis (profit the FMC get from selling the share to the owners -- this would yield annual revenue), and cost analysis (Direct and Indirect Operating Cost).
These calculations would be grouped to ownership cost, Management Monthly Fee, and Occupied Hourly Fee.
Now, the objective of the simulation is this :
The simulation should be able to give a result on how many planes needed by the FMC, according to shares available.
So basically the user would have to input the number of shares (e.g., Owner 1 : 1/16 share, Owner 2 : 1/8 share, Owner 3 : 5/16 share -- it'd add up to a (1) full share). The end result should be how many planes needed to serve the demand available from the owners.
Assumptions :
- The more share the owner got, the more likely he'd use his share (to fly)*
- Only one type of aircraft.
- Only one destination X (instead of multiple destinations). I'd like to keep it as simple as possible first. Then if it's possible, then i'd upper the ante.
- Doesn't really involve the aspect of crew flight hours etc (if you're in the aviation industry, you'd know that there are limitations on how long pilot and crew are allowed to fly at a time). I'd use a time space of 24 hrs and 1 hour time step.
I currently need help on some few aspects :
- Do I convert the share to flight hours first, or do I let it stay as "share", so I can use it as a fraction (that effects the possibility of the owner to use their share)?
- Do I really have to use many variables to illustrate different owners and/or share, or can I use one variable with commands in it? I haven't really get the grip of using "if-then", because I haven't learn it from the Road Map -- see below.
- How to model the chance of owners using his share in the duration of 24hrs? And to convert it into the "needed number of aircraft"?
FYI,
- I'm using Vensim DSS.
- I'm reading MIT's Road Map - A Guide to Learning System Dynamics. So basically I'm reading and doing the exercise. But not much luck with the effort to make "perfect" models in the exercises :(
- I'm attaching my veeeery rough and horrible model for all of you to laugh..er, look at.
Thank you for any answers. All helps are greatly appreciated! And sorry for my bad English, it's not my mother tongue :)
*It's similar to the principal in the MIT Road Map 5 - 4 Generic Structures S-shaped Growth 1.pdf - p13 :
"The probability of a healthy person coming into contact with a sick person is proportional to the total number of sick people in the population. Therefore, the more sick people in the population the greater the chance of coming into contact with one."
So the more share the owner got the greater the chance of him using it.
[Edited on 10-12-2009 by toukairin]
sketch_FAO_early.mdl
(3.35 KiB) Downloaded 487 times
Aircraft
I do not know if you got some help with your problem, but some people in the past tried to get some help with problems that required to much work from the forum members, who have too their own problems. The best solution if you want to get some help, would be first to simplify your problem to the utmost imaginable even if it is very far from the reality, and it is possible to go very far in this direction. A simple problem for instance could be explained with a maximum of 20 words. Once done, try to solve the problem by yourself. If you cannot, then ask for help that you have more chance to get, your problem being very simple to explain at least with simple English words. If you get an answer you will have learned something and you can eventually get a bit further and ask another question a little bit more complicated and so on. I think it is better to have a reasonable chance to get something little (an answer to a simple question) than to have no chance to get something big (the answer to a more difficult question).
toukairin
Post by toukairin »
LAUJJL, thank you very much. I appreciate it. I'll try to simplify it first, I'm also tweaking my model as I'm reading the Road Map. When I can get it "reduced" to a simple problem,I'll get back here :)
Once again, thanks!
toukairin
Post by toukairin »
Ok, I'll try to address my problems one at a time. I think some of them is more technical and Vensim-focused instead of general System Dynamics. Should I make a new thread in the Vensim subforum or should I just put it here?
It depends. If the question is likely going to be of use to someone else (for example, how do you allocate a finite resource to multiple tasks), then start a new thread. That way if anyone searches for a particular problem, they are more likely to find an answer.
