Monte-Carlo output
MarBis
Monte-Carlo output
Post by MarBis »
I am running a Monte-Carlo simulation on my model for 100 runs. Once it is over, I can choose either the Sensitivity Graph or the Statistics output to see the default reports.
The Sensitivity Graph provides information regarding how did the mean and percentiles evolved through time, but only graphically, while the Stats outcome provides numerical information of the same but only at a certain point in time.
What I want is to get is a combination of the two, the statistics data for each time point throughout the simulation in a table-like form; essentially it is all the information that the Sensitivity Graph reports (including the mean and st.dev.) but in a table form.
Any hints? Thanks in advance!
Marios
I think what you'll need to do is export the output to a spreadsheet using Model>Export Dataset..., so you can perform those calculations externally.
MarBis
Post by MarBis »
Thanks Tom, that worked fine!
